wich short block to build
well my buddy always tells me to build a b20 block...he has one and fricking pulls hella hard with his type R head....i got a b16 in my hatch and i was planning on build a block in school next semster....just cant decide which on to go with a b20 or keep it 1.6
i know the 1.6 has a really good rod to stroke ratio and the plan was balance the crank flywheel and pulley as an assembly then forged rods and ctr pistons i think
then agian i can build a a b20 block dont really know what to do just need some help making a decision
if it helps i was hoping to autocross the car and some draging ....hoping to make around 210-230 horses n/a with a built head
thanks for the help
thanks for the help
Re: wich short block to build (whatsthatnoise)
no thanks i dont want to be just striaght drag car i want to autocross it too....dont want to throw off my wieght balance
Re: wich short block to build (95redeg6)
b16 has a lot of potential. i like your idea about balancing the crank and throw some ctr pistons in there, why not a stage 1 cam while youre at it, thing will fly!
But yeah if you ever want to see any torque better to up the liters. I like a 1.6 personally though, if you do all that to it youll be pissing off a lot of guys with stock gsr swaps
1 Post
im not a big fan of b20s. Cylinder walls crack easier than most other B-series blocks.
I'd go with an LS or GSR bottom end. dont do the b16. rod stroke, etc. Not going to matter for a daily driver.
Re: wich short block to build (exospeedAMcrx)
cylinder walls should hold up though right if im not boosting it on the b20
my buddy has his b20 v fully built and it is a 10k screamer...holy crap it is fast but i was just worried about the rod stroke ratio
just thinkin that a 1.6 would be more reliable built then the b20
thanks agian for the insight
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95redeg6 »</TD></TR><TR><TD CLASS="quote">
ya theres alot that hold, but from experience and what we've seen out there, theres alot more cracked b20 cylinder walls than anything else.
We just had a customer from Arizona come in last Monday and they were using B20/Vtecs for their roadrace/autocross cars and they went through 3 b20 blocks just this year.
Re: wich short block to build (20CiViCSi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20CiViCSi00 »</TD></TR><TR><TD CLASS="quote">1.8L LS/VTEC aka frankenstein motor</TD></TR></TABLE>
2.0 liter GsR or LS/V. Not the cheap route, but it works.
adonis2oo2
30
01-04-2007 10:31 PM
