why is there noise coming...
just wanted to know why there is noise coming from the back left and right side. i got h&r springs matched with kyb agx's at 1.75 drop in front and 1.5 in the rear. is it just because they are settling, or is this something that i should be worried about. anything would help.
Re: why is there noise coming... (distortedfuture)
I also have this problem with my H&R's and my Koni Yellows. It kinda sounds like there's a metal washer being shaken around in a soda can. But, everything is working fine and tightened up well.
Re: why is there noise coming... (AntiRice Superstar)
I have Koni Yellows with Neuspeed Race Springs (don't evAR buy these ) and they rattle around also. I made sure everything was to spec....
Re: why is there noise coming... (GTlvr82)
I had that problem with my Neuspeed Race's (don't ever buy these), but it turned out that the spring was sitting directly in the cup of the upper mount thing. When I corrected that it got rid of the rattle. Also, you guys didn't take out your spring insulator's did you? that would also cause a rattle, I think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiRice Superstar »</TD></TR><TR><TD CLASS="quote">I also have this problem with my H&R's and my Koni Yellows. It kinda sounds like there's a metal washer being shaken around in a soda can. But, everything is working fine and tightened up well.</TD></TR></TABLE>
yeah, that's pretty much how it sounds. not that a bolt is loose.
i have a loud clunking sound from my rear right. i hae sus. tech springs with tockico 5ways. i have checked everything, strut mounts, bolts, the lca, and eveyrhing, cant seem to pin point it. anyone?
