why the hell is the battery light on in my car????
I have an 01 civic lx, and today driving home the battery light started flickering the higher the RPM the faster it flickered untill it went out eventually....then when I get home I tuen the car off then back on it permently stays on unless the RPM's raise and in that case it flickers again.....car has 39k on it the alternator should not be going out and I would think the battery should be fine its only been in the car 4 years.
Re: why the hell is the battery light on in my car???? (Lysawy)
yeah the light is there becasue the battery is not being charger appartently.....thats where the confusion is, why is the light flickering, why did it go off only to come back on once the car was turned off then back on
Re: why the hell is the battery light on in my car???? (JMX)
help please, as many possibilities as possible so i can check them out first thing tomorrow
start the car pull off the negative battery cable if the car dies then it is the alt. but it sounds like an alt. problem to me
I had a voltage regulator go out on mine once. Did the same thing because the voltage the alt was putting out was like 9-10 volts for a minute and then a 16-18 volt spike. It sucked. Autozone or Advanced will check the alt and the battery for free though.
Spence
12-11-2006 02:27 PM
