Why does my civic do this.
When i'm on the fway doing more than 60 mph the car will go to the right when i accelerate and when i let of it goes to the right.. BAD.
Re: Why does my civic do this.
No the car runs straight does not make any clinking noises or need alignment (done just in case) has a different tranny because i though the tranny was the issue. When i'm on the freeway the car will go the right when i accelerate and will go left when i let the gas go back straight or quit pulling the right.
If it turns, the axle shaft (not the CV) might be broken.
Check your mounts, 1 might be broken causing the engine to move and making your axles articulate at a bad angle causing drag.
Then check your wheel bearings, jack up the car and turn the wheels to see how smoothly it turns. You need to do this for both front and back.
bluevic99
10-09-2011 04:55 AM
