Why does my car shake a lot? like if it has the chills..
Old 05-31-2009, 07:04 PM
Intake_Kush's Avatar
Icon2 Why does my car shake a lot? like if it has the chills..
Well is pretty much what the title stated my car shakes a lot when I put it on drive or reverse or when it's in a full stop and holding the brakes it shakes aggressively even the dash shakes but if I put it in park it stops. I want some ideas on what it can be any opinions are welcome I just want to know what it is and I doubt that the spark plugs are the problem. Oh by the way my car is a 97 civic LX automatic with a D16y7 engine. Thanks for anyones help
Old 05-31-2009, 07:12 PM
bbsprelude's Avatar
Default Re: Why does my car shake a lot? like if it has the chills..
sounds like a bad motor mount. look to see if the rubber on any of your mounts is torn, cracked or just not there
Old 05-31-2009, 07:16 PM
That sounds possible I didn't think of that I will check that first thing tomorrow thanks Any more ideas in case that isn't it?
Old 05-31-2009, 07:19 PM
infinitypro12's Avatar
What about in neutral, instead of park? It could be like 10 different things; however, due to the face that this only happenes when you are in gear i would check your motor mounts like bbs stated, if that is not it then I would also try the transmission. Technically when your car is running whether it is in park or drive the engine is obviously working; thus, it sounds like when you engauge a gear your car shakes and when you aren't engauged it is fine, correct?
All in all, we can just do what we can to narrow it down...up
Old 05-31-2009, 07:20 PM
bbsprelude's Avatar
maybe a torque converter problem, but that's a big maybe. i would put my money on a bad mount
Old 05-31-2009, 07:44 PM
Yes, your correct only when the gear is engaged well I haven't tried it on neutral yet will check that out. The transmission was rebuilt less than 2 months ago so I don't think that's the problem cause it runs smooth. I'll check the mounts tomorrow like bbsprelude said. Yeah basically that's what I'm trying to do with this thread is to narrow down the things that might cause it to shake.
Old 05-31-2009, 07:46 PM
stevenDAtegra's Avatar
well sometimes when things get rebuilt they only last a little bit if some specs or clearances were off. As stated before though, I'd check mounts first
xkitex
28
07-17-2012 04:22 PM
scspeed
05-28-2009 08:00 PM
ef602
04-13-2009 12:15 PM
Kyles ej1
10-07-2004 11:09 AM
kidaniel
04-22-2004 02:38 PM
Quick Reply: Why does my car shake a lot? like if it has the chills..
