whole on rim help jb weld?
I have a hx rim
It has a lil whole in it it leaks air, everyday I have to put air in it meaning the hole is little so I was woundering if jb weld will do the job if I put it on both sides ( inside and outside of the rim)
Any sugestion will help
Thankz
Thankz
Re: whole on rim help jb weld?
Is not big just lil lil tiny 1
But am going to to 3 layers
Like at 6 ama do 1 after I sand down the sorounding
Then like at 9 another layer n then at 12 the last 1
N hopefully tomorow I can put it on
Maybe if you gave it longer than an hour and a half you would get some responses. Also, most of the 53 views were to just see what "whole on rim help jb weld?" meant. Maybe if you put "JB Weld on rim" or "Hole in rim would JB Weld help?" you would get some real answers. And SF_Dee appears to of fixed the same problem you are having with epoxy for metal.
TURBOED-TEG
11
01-17-2003 11:08 AM
