where is the tranny code?
Re: where is the tranny code? (IVI)
there should be a white sticker with barcode around the bell housing of the tranny. just above where the vin plate is located in other words just above to the left of the block stamp.
Re: where is the tranny code? (eg6si)
my sticker was like a reflective aluminum color but i accidently wiped out whatever it said with brake cleaner a long time ago.
is that the only spot where they put the code? on a sticker ?
the brake cleaner cleaned my sticker off, cleaned the ink off too, now its just a plain clean sticker.
there is no other way to find out ?
thanks for your help so far, but i dont understand reading the gear ratios.
i can eliminate the last 4 which are cable since i know its a hydro
other than that, im not sure...
is it that you just want to know what it is you have or do you need to know what tranny you have because of maintenance issues?
