where is my fast idle thermo valve???
Old 03-19-2002, 05:20 AM
New User
topher's Avatar
Default where is my fast idle thermo valve???
on my b16a2/3 motor??
I cannot find my haynes manual
and this is bugging me
and if i am correct, to check for function on it
i remove it
and if there is vacuum at idle(as my idle lopes) that means the valve is malfunctioning??
Old 03-19-2002, 05:49 AM
Doctor CorteZ's Avatar
Default Re: where is my fast idle thermo valve??? (topher)
its under the throttle body,with one coolant line and 3 10mm bolts
Old 03-19-2002, 07:51 AM
Robster's Avatar
easy way to test if its bad, take the intake tubing/piping off the t-body, start car, put finger on bottom hole in front of the throttle plate, if you feel suction, the fitv is bad.
Old 03-22-2002, 12:17 PM
New User
topher's Avatar
Default Re: where is my fast idle thermo valve??? (Robster)
i need more info
where is this thing???
Old 03-22-2002, 12:56 PM
Plan B's Avatar
okay, this is under the throttle body. That's the only way to describe it. It has one coolant line going to it, and the 3 bolts. One thing i've learned is that this thing is adjustable. Although honda says it is not. You can take it off the throttle body and remove the cover on the firewall side of it. You can then turn the white piece around the metal thingy. (sorry i'm being so technical) Once it's all the way tightened up it should work fine. Althogh when i tried this on mine, i accidentally put a hole in the diaphram, i found a used one for $35, but i think they cost around $70 from honda.
Hope that helps.
Honda4life777
03-11-2010 02:05 PM
mmpama23
04-15-2009 12:47 AM
EFstyle
07-29-2008 07:09 PM
bboixtc
01-30-2008 09:38 AM
OneThirtyEight
10-21-2002 12:52 PM
Quick Reply: where is my fast idle thermo valve???
