wheel size, tire size and my speedometer
alright this is probably going to be a retarded question but i was wondering if my 1994 civic hatchback's speedometer would read different if i put some 14's on it. (the question is more of how much will it cange if any. i currently have some 13's on it
thanks!
thanks!
Re: wheel size, tire size and my speedometer (jdm1994hatch)
depends on what size tires you use on the 14's. try to keep to stock diameter when switching wheels/tires
http://www.miata.net/garage/tirecalc.html use that calc to run some test
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm1994hatch »</TD></TR><TR><TD CLASS="quote">alright this is probably going to be a retarded question but i was wondering if my 1994 civic hatchback's speedometer would read different if i put some 14's on it. (the question is more of how much will it cange if any. i currently have some 13's on it
thanks! </TD></TR></TABLE>
Go here:
http://www.discounttire.com/dtcs/infoTireMath.dos
Go here:
here is two links that if used in the right combination can help you find out exactly what your speed correction varialnce will be.
Use the Discount Tire link to find your wheel overall diameter and use the Autocrossing link with your appropriate setup to find out your vehicluar speed at a specific RPM.
Do some research next time, people like me will not always be there to give you the answers......the Search function is your friend.
http://autocrossing.com/cgi-bin/gearcalc.cgi
Stock for your car is 175/70-13, the correct 14" size (or plus 1 size) is 185/60-14. This will have a larger diameter of 0.4% (or a little less than 1/8") which is nothing. Your speedometer, odometer, and acceleration will not be affected. Nor is it expected you experiance any rubbing as long as you run the proper offset.
Hope this helps.
Also there is a wheel and tire forum on honda-tech.
Cheers.
Hope this helps.
Cheers.
