wheel change.....performance diff?
so heres the deal,i got some 16x7 rotas with 205/40 yoko a520s right now and im seeling them and i need new wheels for the summer. Im thinking about picking up these ls meshes that i can get for a killer price.If i get these, i would put 195/50 azenis on them. My question is, would there be a noticable diffrence in the handling between the two. Im mostly concerned with switching from a 7in wide wheel to a 6 in wide wheel. bring it on with the coments.
Re: wheel change.....performance diff? (second edition)
there will be a difference... depending on your car, you may or may not have power steering. switching from a 185/65/13 to a 215/50/15 drag radial is huge! (thats my case)... 30mm (3cm on each side) is a drastic change. my little hands were struggling (i have no power steering).
in your case, 205 to a 195 is not huge, nor is 7in. to 6in.
but... you'll feel a difference, just depends how much if you're weak like me
Risky Business
If you put LS meshies on, the only available size for azenis that you would be able to use is 205/50...the 195/50 azenis are only in 14". And your car would handle probably 3 times better because azenis are one of the best gripping tires for under 100 bucks that you can buy.
Import Al
10
11-12-2005 08:25 PM
pagong
21
02-22-2003 07:23 AM
