What Will fit on a 1997 Del Sol Front
hi im new here..
i got a 92-95 civic si lip from my friend and tried to fit it on and apparently it didnt work...i saw pictures online and it work out right hows that?
i know that a 92-95 si lip can fit on the old del sol front such as the 93 year or so
i really need help, if anyone can help me on what can fit on a 1997 del sol front please let me know
It's called a "CONVErSION" it's not goin t bolt right up, your goin to have to get it fitted to the car, I did a 2004 Celica Front End conversion on my 95 sol.. Currently gettin the pieces together to do a saleen s7 front end/body modification to the car. GOOD LUCK!
Re: (DelSol-B-18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSol-B-18 »</TD></TR><TR><TD CLASS="quote">It's called a "CONVErSION" it's not goin t bolt right up, your goin to have to get it fitted to the car, I did a 2004 Celica Front End conversion on my 95 sol.. Currently gettin the pieces together to do a saleen s7 front end/body modification to the car. GOOD LUCK!</TD></TR></TABLE>
Thats not right, mine bolted up perfect on my 97 front end
I just did this on my 95 sol. There is a tutorial on this let me search.
EDIT, here you go man.
http://www.teamdelsolwa.com/howto.html
its #5 on that list, you might get some use out of the other links as well. good luck.
The only tip I can give you is start from the sides of the bumper and work your way to the center. You can line it up better.
prose
prose
Re: What Will fit on a 1997 Del Sol Front (skip.two)
im serious it doesnt fit its to short to wrap around the the sides for i can drill holes
Re: What Will fit on a 1997 Del Sol Front (ProjektSol)
the only real difference is in the bumper with the del sol, its different entirely with the civics I belive.
You may be able to bolt up a 92-95 civic front end with little to no modification but I cant remember 100% right now, I think you may have to drill a few holes in the fender to mount it properly.
make it look good yourself, take a dremel tool, cut out the cetner grill thing, and put a home dept grill in there. THats what i did, and it cleaned it up SOOOO much. But i painted hte grill the same color as the car (it was on when the bumper was painted but looks good)
Nothign looks better than OEM
but the problem is that the lip is to short as in the width wise
i can wrap the lip around the sides to bolt it down n i juss can cut it cause that wont help either
Re: (ProjektSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSol »</TD></TR><TR><TD CLASS="quote">but the problem is that the lip is to short as in the width wise
then i believe you should get the correct lip to do this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
i can wrap the lip around the sides to bolt it down n i juss can cut it cause that wont help either</TD></TR></TABLE>
Re: (ProjektSol)
i have seen quite a few places actually make lips specifically for the del sol, try searching on google or ebay.
you can also try any del sol forumn, you'll probably get more help there. the only thing is it might take a while since they don't get as much traffic.
chicken18
34
05-30-2009 03:04 PM
95GSRBOI
10-06-2005 07:33 PM
mrDFWmechanic
18
05-14-2005 06:07 PM
DelSlowdier
11-28-2004 11:00 PM
