what welder yall use for clips spot welding,wire welder?
Re: what welder yall use for clips spot welding,wire welder? (gulf imports)
yup automatic wire feed makes welding simple and fun. i beleive the one i have is a lincoln....make sure u get a good one with a voltage control AND wire feed control!
Re: what welder yall use for clips spot welding,wire welder? (DubbleD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubbleD »</TD></TR><TR><TD CLASS="quote">yup automatic wire feed makes welding simple and fun. i beleive the one i have is a lincoln....make sure u get a good one with a voltage control AND wire feed control!</TD></TR></TABLE>
I have access to snap-on...
Re: (gulf imports)
you are going to weld a clip together?
You are going to need a lot more then a welder to make it safe.
I wouldn't do it. They are known to break apart in even minor accidents.
Re: (Emerika)
I use a Lincolin weld pak 100 with argon gad its a wire feed with good heat range and wire speed Ive welded mounts,clips,exhaust ect with it,works great!!
ricodemus
Welding / Fabrication
05-20-2010 07:50 AM
