what swaybar will fit?
New User
on an 97 civic HX coupe
what rear sway bar will fit with out any modification (changing LCA's)
will a stock SI bolt right up
did a search but didnt really answer my question
and if the SI does fit is anyone selling one cheap ?
thanks
thanks
Re: what swaybar will fit? (nevergiveup)
a stock si rear will work.. you just need all the stuff for it ie. endlinks, bushings, d brakets etc. i believe its a 13mm bar. the ITR is bigger (22mm).
Re: what swaybar will fit? (mantic6t9)
do i have to get new LCAs to put a rear sway bar on my eg hatch? IT doesn't have wholes in the lcas.
Re: what swaybar will fit? (C1V1C)
it sucks you would figure they would put a sway bar in the si hatch but no, not in 93 anyway. Another thing do the integra LCA use the same shock to lca bushings? i have ES bushings i would like to use, i had to put them in when i installed my koni yellows. I noticed you have koni yellows how many perches are on yours. Mine have 5 on all 4 shocks. I'm starting to thing they are the neuspeed koni yellows 'cause everyone else says they only have 2 settings in the front and 3 in the back. LAter...
[Modified by mantic6t9, 1:20 AM 1/25/2002]
New User
The 99-00 Si sway will bolt right to it with the endlinks, bushings, etc, but it's only a 15mm bar, you'll notice a difference but won't be very much. Mugen makes a sway bar kit, that encludes a chassis reinforcement kit, you'll still need the Si links and bushings. I did the Mugen 22mm and I LOVE IT... http://www.kingsmotorsports.com
Re: what swaybar will fit? (LRCivicEX)
where did you find the ITR rear sway bar? I'm looking for one. Also, what else did you need to install? I drive a 00 ex.
New User
Re: what swaybar will fit? (tFUnK)
So an ITR rear sway bar will just bolt up to the 97 civic coupe?
with all the end links and stuff (for the SI right?)
now a question
the car will not be put into any competition
so will it be better with no mod and get the SI sway
or
drill holes and get the ITR sway with beaks reinforcements?
or
just go get the comptech rear tie/sway bar
any opinions will be appreciated
[Modified by nevergiveup, 12:57 AM 1/25/2002]
now a question
or
or
New User
Re: what swaybar will fit? (onefastcx)
hey onefastcx
what do you mean by no modification
thought you had to drill ahole for the brackets to fit caz the 2 stock hole is too close
because the stock SI sway bar is 14MM or so and the ITR is like 22mm (correct me if im wrong) so the ITR is thicker so the stock bracket holes will not line up.
thats why i put the beaks reinforcements caz if i make a hole i want some reinforcements.
so the question is
"is the ITR sway bar worth the hole and extra $ for reinforcements?"
thanks alot guys
so the question is
thanks alot guys
New User
Where did you find that for $80...I would like to know...but a little information if you didn't know this...the ITR rear swaybar is made by Mugen, Honda buys them and makes their own hardwear for the kit...by the way I paid TOO much for mine...
New User
so you want a Si sway bar eh? you might have to drill two holes on your LCA for the bolts. other than that, it goes right in. if your interested, i'll sell you mine with everything (endlinks, bushlings, bolts.) for a good price in perfect condition. e-mail me chubbibabies@excite.com if your interested.
New User
Re: what swaybar will fit? (ToneyTigre)
well i decided to get the mugen from a guy on this board
selling everything with bar for 170 and the bar is from kings
well im going tonight looking at it and if its really clean im buying it
how much for the SI with all the hardware toney?
New User
I already have one...I bought the 22mm Mugen kit for the EX about a year ago, the only thing I had to buy was endlink and mounting brackets, at the time I worked at a honda dealer so I got it cheap...I ****ing love it man...thanks though
zoopreme
06-16-2010 01:18 PM
denniscoles
08-14-2007 07:39 PM
wdskuk
09-21-2003 08:17 PM
