What Spring Rates Do You Daily Drive on?
I plan on getting suspension in the future and wanted to see what spring rates are recommended for daily driving? I want the ride to be comfortable while still maintaining a performance feel. Has anyone found the perfect balance? What spring rates are you guys riding on? Describe it as well. Is it too bumpy or to stiff?Keep in mind i live in the bay and some of the roads suck...thanks
Re: What Spring Rates Do You Daily Drive on? (backseatDRIVER)
I live in the Bay as well and I'm daily driving on 10k/6k (~550lbs/350lbs) springs and it's not too bad. It's a bit stiff, but it only sucks driving around in downtown SF. Other than that, I would say they are tolerable and not too uncomfortable on paved roads. These are Omnipower Full Street Coilovers, btw.
Re: What Spring Rates Do You Daily Drive on? (_Project EJOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Project EJOne »</TD></TR><TR><TD CLASS="quote">I live in the Bay as well and I'm daily driving on 10k/6k (~550lbs/350lbs) springs and it's not too bad. It's a bit stiff, but it only sucks driving around in downtown SF. Other than that, I would say they are tolerable and not too uncomfortable on paved roads. These are Omnipower Full Street Coilovers, btw.</TD></TR></TABLE>
Thanks those were the coilovers i was looking into actually. It is ethier that or a koni/gc set-up with spring rates of my choosing.
I've got Neuspeed Race Springs with the stock struts. I don't really know what the spring rate is b/c Neuspeed's website doesn't say but I do have a somewhat stiff ride but very tolerable. I've been riding on them for about 3 years now and wouldn't change a thing. I just think the if I would get some adjustable struts, it would make everything that much better.
#1 Super Guy
Re: (backseatDRIVER)
It is more comfortable, especially if you ever have anybody in the rear seat.
I have 400f/250r ground controls w/ koni yellows in my 94cx, and it is great on the street (I never tried autocross). With softer rear springs you need to compensate by having a stiffer rear swaybar (not "ideal" for racing). My friend has coilovers with stiff springs in the rear, and when he drives over dips, I can feel the rear end lift off the ground. I rode in his back seat once and it was torture (stock shocks = bouncy).
well in general high front rates and low rear rates (in comparision) cause the car to understeer. (front biased)
High rear rates, and low front rates (in comparision) cause the car to oversteer. (rear biased)
now those are just general rules. there are a few racers that run the high front low rear, and there car's over steer, but generally the alignment is very important.
but then again the alignment is very important with the rear biased setup too. But more often then not, most of the time you can get the toe zero'd out and just use your normal camber from lowering
Re: What Spring Rates Do You Daily Drive on? (b_cruz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz. »</TD></TR><TR><TD CLASS="quote">I drive on 10K/12K.... if I wanted comfortable, I would just take my GS400 that day.</TD></TR></TABLE>
i wish i had the option of that luxury
buy my Lexus then biatch.
Also I have the 12K's in the rear.
daily driving isn't that bad. really.
Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">450lbs.F - 1000lbs.R </TD></TR></TABLE>
do you like to *** drag your civic? thats the stupidest **** i have seen in a while
Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
do you like to *** drag your civic? thats the stupidest **** i have seen in a while</TD></TR></TABLE>
how do you figure?
with a user name like 'slammed_93_hatch' you are far from a road racing suspension god.
how do you figure?
Re: (craniumcrack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by craniumcrack »</TD></TR><TR><TD CLASS="quote">
how do you figure?
with a user name like 'slammed_93_hatch' you are far from a road racing suspension god. </TD></TR></TABLE>
errr that was a long while ago, that that pic was taken and at that time my suspension was for daily driving.
I made my user name in 02 LONG *** time ago.
I knew back then with my car that low it didn't handle as good as it could, thats ok cause i don't race around on the streets.
My suspension now, is still a work in progress and consistently tunning. But its not a daily driver any more.
this poster asked for DAILY DRIVEN SPRING RATES. driving on the street with a true 1000lbs springs rate on a civic is fuckn stupid.
I never claimed to know it all, but i do know my fair share, and that setup is just stupid.
Modified by slammed_93_hatch at 11:54 PM 11/11/2004
how do you figure?
Re: (toadolson)
Forgot
A big determining factor is progressive rated and liner rated springs. The difference between the can make for a smooth or not so smooth ride.
Same here, just switch "GS400" with 94 Pontiac Grand AM.
Re: What Spring Rates Do You Daily Drive on? (chad)
GC/Konis (yellow). 325f/350r great for autox, but a tad stiff on bad roads. I'm in the baltimore area and the streets here are second only to the roads in detroit. I wouldn't go over 400, but it's all about personal choice. I'm sure someone will disagree with this.
I have no clue how you guys ride around on anything over 400 lbs. There's no way I could do that around here. You guys are soldiers.
