What size tires should I run?
So basically after 3 years of riding on cheap ebay coilovers and blown shocks, I've decided to put an oem suspension setup back on my Civic. I have 16'' Enkei CDR-9 rims with 205/40/16 tires. the only problem is that im not sure how my car will look with the low pros once it's back at stock height. any suggestions?
The Grumpiest
Re: What size tires should I run?
It will look pretty odd. What suggestions are you looking for? Even with the stock tire/wheel stock height looks stock. Might be waaaaay too high for you. A taller sidewall size would help but not much.
Crazy Honda Guy
For a regular daily driver, i've always liked a quality set of lowering springs (they ride so much nicer than most coilovers) down about 1 1/2".
16's are fine, 15's are even better performance wise
here's my civic coupe at stock height with 16's
here is lowered
here is lowered
i was thinking maybe some 205/45's or 50's. plus if i put it back at stock height and dont like the result, i can always get some new springs lol. but for now im gonna do myself and my suspension a favor.
To me your car at stock height really didn't look bad. i might go with some 50's to reduce the gap between the tire and the fender. also, i read your thread on your civic a few weeks ago. that is a nice car my friend.
I think a set of some tokicos and some lowering springs would cost about the same as oem stuff. your talking about spending 400ish+ dollars to get bigger tires when you could put that towards your suspension instead.
Keep in mind taller sidewalls will throw off your speedo reading. 16" wheels call for a 205/40 or 195/45 to keep the speedo reading close.
Ek Forever y0!
JDM ITR's with the 16" wheels had 205/50 tires.
205/40 is the "sporty" tire that throws the speedo off.
205/45 is the closest you can get to the oem civic size wheel/tire diameter. It's still a few percentage points different.
lol at the damn monster truck tire. a 45 or 50 sounds good. im still pretty much set on going back to oem shocks. the roads where i live are horrible and last week i got my car aligned for about the 4th time in a year due to the **** coilovers it has. at least with the oem setup i wont have to deal with the hassle anymore. plus when its out of alignment it eats my tires.
i have 205/40/16 on my eg and i want to put 45's on because there too much room in between. I have 45's on another set of tires and if i went to 50's the tire will hit the fender if i turn the wheel.
Any time you change the ride height the car needs to be aligned, period.
You should get your car aligned at least 1 time a year. Also, every time you switch tire/wheels it should be done again.
