what parts r all in a complet bottom end?
im thinking of doing lsvtec or just ls but im buying a ls bottom end and im curious what all comes in it if u could help me out i would be most happy, tanx
Re: what parts r all in a complet bottom end? (Teal5GenHatch)
bottom end, or short block, oil pan, pistons, rods, bearings, block,all that kinda stuff, it wont have the head or dissy or anything like that might not even come with the coolant stuff on the back of a block...
Re: what parts r all in a complet bottom end? (eddiecut)
i know it comes with the.., oil pan, pistons, rods, bearings, but does it have like exhaust mani i kinda need help with every part it a complete bottom end comes with cause im gunna buy tomar if u know a site or anything that would help tanx man
_______
_______
The LS is a good engine but if you want to go VTEC then buy a VTEC engine! Dont dick around with an LSVTEC. If you dont believe me then find a pro racer who is using one. Also it costs more money than the VTEC engine would! OK im done for now enjoy.
Re: what parts r all in a complet bottom end? (civicrights)
im getting hook up on parts so $ is not a hudge issue but... lsvtec i do relize is unstable and needs alot of work, but i might just do lsturbo.. i still need to know the All the parts that it comes with in a complete bottom end tanx guys
thats retarded, i know some pro racers that do use ls vtec and have had alot of good luck with them, big key right here need to be done RIGHT..... they are not an unstable motor, its how you put it together but isnt that with anything??
ive seen 2 many lsvtec swaps unless u invest serious amounts of time and $ to build it riite ur gunna have probs but anyway never the less this is not my quetions i was just asking whats all in the bottom end im buying a block 2 mar and i need to know what to look for tanx mang
are these all the parts?... Camshaft Seal
Crankcase Gasket Set
Crankshaft Pulley
Crankshaft Seal...
Cylinder Head Gasket
Cylinder Head Gasket Set
Cylinder Head Seal
Engine Mount...
Engine Mount Stop...
Exhaust Flange Gasket
Exhaust Manifold Gasket
Exhaust Valve
Intake Manifold Gasket
Intake Valve
Oil Drain Plug
Oil Drain Plug Gasket
Oil Filler Cap
Oil Filter
Oil Pan
Oil Pan Gasket
Piston Ring Set
Rod Bearing Set
Spark Plug Seal
T-Belt Tensioner Spring
Timing Belt
Timing Belt Kit
Timing Belt Tensioner
Timing Cover Gasket...
Valve Cover Gasket
Valve Cover Gasket Set
Valve Cover Nut
Valve Cover Seal Washer
Valve Guide...
Valve Stem Seal...
Crankshaft Pulley
Crankshaft Seal...
Cylinder Head Seal
Engine Mount...
Exhaust Valve
Intake Valve
Oil Drain Plug
Oil Filler Cap
Oil Filter
Oil Pan
Oil Pan Gasket
Piston Ring Set
Rod Bearing Set
Spark Plug Seal
Timing Belt
Timing Belt Kit
Valve Cover Gasket
Valve Cover Nut
Valve Guide...
Valve Stem Seal...
