What is needed to make b20 complete?
I buy a b20 longblock...
these are the things that i think is needed.
-mounts
-ecu
-harness
-b series tranny
Would i also need the ls intake manifold? Because i heard the b20 IM would not clear in a hatch or so...is this true?
-mounts
-ecu
-harness
-b series tranny
Re: What is needed to make b20 complete? (MAD SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SOHC »</TD></TR><TR><TD CLASS="quote">IM and Shift linkage, and of course a B16 head!</TD></TR></TABLE>
lol am i suppose to use the ls IM or can i use any other of the b series IMs?
Re: What is needed to make b20 complete? (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">
lol am i suppose to use the ls IM or can i use any other of the b series IMs?</TD></TR></TABLE>
if you searched you know that nearly all B-series parts are interchangeable.
Re: What is needed to make b20 complete? (95cxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch »</TD></TR><TR><TD CLASS="quote">if you searched you know that nearly all B-series parts are interchangeable. </TD></TR></TABLE>
not quite. you may need an LS intake manifold. you have to use a LS one b/c the gsr and b16 have a different bolt pattern for the i/m. the low compression b20 usually has a tall i/m that wont clear the civic hood, but the high compression one will have a flat i/m.
you also dont need to buy a harness. just use your stock one and mod it (very minimal) to fit the b20
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch »</TD></TR><TR><TD CLASS="quote">that IS true.........the gsr and B16 im's won't work.</TD></TR></TABLE>
sure they will :
sure they will :
Re: What is needed to make b20 complete? (not so civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">sure they will :
ok fine. they wont bolt on, but almost anything is possible if you have access to a good machine shop
1 Post
Re: What is needed to make b20 complete? (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
ok fine. they wont bolt on, but almost anything is possible if you have access to a good machine shop</TD></TR></TABLE>
or a cheap *** drill and a good bit along with a dremel and a gasket to mark your holes. i can put a b16/itr intake on a ls in 15 min's.
i won't ever do another gsr on a ls/b20 head . took two days.
oh yeah, my buddy just put a b16/itr intake manifold on his h22 civic and it's badass seeing that on there.
the b20 z im will clear the hood.. the one that wont clear is the b20b.. that is the massive one.. b20z is the same one as the ls.. b20 is the same as the b18.. the only difference is the bore and stroke.. basically a 1.8 stroked to 2.0
