What mounts do I need for B18b swap in EK hatch??
Re: What mounts do I need for B18b swap in EK hatch?? (chad)
Bump this up! I did a search and found this thread.
In the link above I read this:
"- pull the whole wiring harness out of the car. That's right, the main wiring harness from the engine to the ECU."
Didn't have to do this when I dropped an obd2 GSR into my EG hatch
So, what mounts for b18b into EK? If someone can post a link to another thread discussing this..... then I must suck at the search function
Found this deep in the Hybrid forum
Re: What mounts do I need for B18b swap in EK hatch?? (Hybrid93Hatch)
https://honda-tech.com/zerothread?id=1209479 I just made a reply with what you need at 5pm today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me @ 5PM »</TD></TR><TR><TD CLASS="quote">A/C Mount - You can use the stock B18 but if you want A/C you will need the bracket from a 99-00 Si, Delsol VTEC, or CRV.
Front Tranny Mount - Need the one for whatever tranny you're using and you can reuse your stock civic rubber.
Rear Tranny Mount - Need a bracket from a 99-00 Si and you can reuse your stock rubber.
Top Tranny Mount - Reuse all your civic stuff here, bracket and rubber.
Drive Side Top Mount - Need a 99-00 Si Bracket (piece with 2 studs) and you can reuse your stock rubber
1SickHb
07-11-2004 08:56 PM
