what mount kit is everybody using?
Re: what mount kit is everybody using? (eddiecut)
i am using oem eg motor mounts with prothane inserts.
a little rough at idle and take off but i like it
Re: what mount kit is everybody using? (mysideperformance)
You don't need a mount "kit". You use Integra mounts for a b-series into an EH2 chasis. 3 Integra mounts and 2 Civic mounts to be exact.
Re: what mount kit is everybody using? (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">You don't need a mount "kit". You use Integra mounts for a b-series into an EH2 chasis. 3 Integra mounts and 2 Civic mounts to be exact.</TD></TR></TABLE>
Re: what mount kit is everybody using? (viet)
ok what mounts are they because, i have a full integra mount kit and for some reason its not working, iam thinking maybe i got sent mis matched mounts but not sure.
Rear, Timing belt side, and lower transmission mounts should all be Integra
A/C mount and upper transmission mount should be Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysideperformance »</TD></TR><TR><TD CLASS="quote">hasport.com </TD></TR></TABLE>
Re: what mount kit is everybody using? (TrickHonda77)
the problem iam having is that the tranny mount for some reason doesnt work right, its for sure a b series, the bolt wont go all the way threw. and the bottom tranny mount wont work either, i even tried a jim fab mount on that one.
The bottom tranny mount should work. Its 3 bolts into the tranny if I remember correctly.
The top tranny mount should be from your Civic, not from an Integra.
Disco Monkey
05-03-2004 04:49 PM
