what is the most voltage you can put to a civic
Old 07-13-2006, 05:30 PM
spluvs2install's Avatar
Default what is the most voltage you can put to a civic
I want to see if anyone knows this b/c I sure don't. What is the most voltage you can run into a 1996 honda civic dx. Is it over 16 volts or under like 15.5 or 15.8vdc? I don't know what the computer can take and what it can't and I'm about to run a 14 volt bank with rests near 16 volts. Can anyone advise??
Old 07-14-2006, 01:39 PM
Default Re: what is the most voltage you can put to a civic (spluvs2install)
so no one on this forum knows what voltage these vehicles can take up to?
Old 07-14-2006, 01:52 PM
Paxil4x4's Avatar
14.7 is ideal
Old 07-14-2006, 02:00 PM
Relic1's Avatar
anything more than 16V and you will start having strange problems. 18V bulbs start popping.
14.2-14.7 is a good high side of the operation of a car.
the alternator will not charge anything more than the stock voltage battery. in fact it may discharge it or simply blow the regulator in the alternator.
Old 07-14-2006, 02:57 PM
i know ideally 14.5 -14.7 would be just fine, but if i run around say 16vdc, would you thinbk this would be bad??
Old 07-15-2006, 07:14 AM
Relic1's Avatar
you'll burn out bulbs quicker and may cause sensors to go out quicker than normal. (O2 for instance)
But the ECU should handle 16, but 16.5 I'd be worried about.
and like I said before, you alternator will be worthless.
redboost10
01-14-2013 03:20 PM
huge230
08-22-2008 05:24 PM
cskiff1
10-09-2004 05:31 AM
dglong
02-01-2003 12:04 PM
AbaZ
10-01-2002 07:02 PM
Quick Reply: what is the most voltage you can put to a civic
