what lugs for group n's?
ok, I just got some rota group n's and im not sure if thier is a certain kinda lug i have to use or what. I just went to put one of them on with the stock lugs and i couldnt get a socket to fit in the wheel hole. Any help is appreciated also looking for some open ended style lugs if u guys have any reccomendations
Re: what lugs for group n's? (NAPIER)
Don't use OEM lugs with aftermarket wheels. Look through classifieds or the Sponsor marketplace for a good deal on tuner lugs.
For example: https://honda-tech.com/zerothread?id=933324
Darth ModerVader
Re: what lugs for group n's? (VG! gurlie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VG! gurlie »</TD></TR><TR><TD CLASS="quote">acorn shaped contact points on lugs...
as long as its acorn wedged..its fine... </TD></TR></TABLE>
If by acorn you mean conical or tapered seat, then that's correct. If instead you mean the more typical usage of the term "acorn" here on H-T (which is ball or "Honda" seat), that's incorrect. The Group N's don't use a lug nut with the same style seat as the factory Honda wheels.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
acorn wedge? wtf is that?
to answer the original question, you want a 60 degree tapered lugnut. that is the lugnut of choice for most aftermarket wheels. acorn lugnuts are for STOCK wheels only.
Re: what lugs for group n's? (v-tech rodney)
http://estores.merchantpartner...id=68 Would these work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote"> http://estores.merchantpartner...id=68 Would these work?</TD></TR></TABLE>
Yes, and Marcus at HeelToe is an excellent seller.
1 Post
yes, thos will work. imho, any lug that need some sort of adapter is a piece of ****.
i think he's talking about the kyokugen's. the lightweight lug nuts that have a key that is easily stripped. the open ended muteki's are good and come with a steel key.
if you don't use an impact gun and instead, use a torque wrench then you will be okay with virtually any lug key.
Slammed Ek9
41
07-10-2005 11:00 AM
Sohc Driver
16
06-04-2002 11:09 PM
