What kind of sway bar is this! will it fit on a ek?
Picked up this rear sway bar from some guy, told me it came off a GSR and would fit on 96-00 civic's. New to the JDM scene so i could had been easily tricked... i only paid $20 bucks, but still im hoping this will fit my 00 civic ex! Anyone know what kind of sway bar this exactly is and will it fit a 00 civic ex?
tips and advice greatly appreciated thanks!
Re: What kind of sway bar is this! will it fit on a ek?
picture isnt showing for me.. just incase heres a link.
http://www.facebook.com/photo.php?fb...4&l=fab2fff3d6
not sure what car it fits, but that looks like a progress rear sway bar. i don't know if they use the same bar for ek and dc though.
It does look like that progress bar.. is it compatible with a civic 00 ex? also here some more detail pictures.
[IMG] Uploaded with ImageShack.us[/IMG]
BUMP! installing it atm.. not quite sure where the ends are supposed to connect to..somewhere near the coilover?
Technical Hero
What size is the bar. If its too large you may need a subframe brace. Actually its probably best that you use one because the EX/DX/LX models didn't have the threaded holes for the sway bar to bolt too like the 99-00 Si model. Also you'll need 99-00 Si rear endlinks as well as the ones that you have above won't work.
#31/32
#31/32
Ek Forever y0!
Considering the mounting brackets it has it's almost surely a progress bar. That's the only company I know of that has those type of mounts in order to avoid using a subframe brace. Progress was pumping out those brackets way before the subframe brace was even invented.
for a cheap bolt on, i would just get a 99-00 SI rear sway bar
if you want something nice, i'd get a JDM CTR EK9 22mm rear sway bar with a subframe brace to reinforce it
you can find it at www.n1concepts.com
The spongeness
Suspension & Brakes
11
04-30-2023 05:53 AM
