what is going on???
what is going on???
A week and a half ago I did an oil change and came up a liter short. Previous to this I had done a compression test and came up with 170, 170,175,170 and never been short on previous oil changes.
I assumed I was burning oil because of the missing oil, but I just did another compression test and came back with 180,180,185,180. On top of that after about 700 kms there is no missing oil.
So what is going on? It is a D15B7 with about 210 000 kms.
Re: what is going on??? (chillax)
perhaps you had a loose drain plug, and after doing the oil change you got it tightened up correctly? did you notice any oil in your garage or whever you park?
Re: what is going on??? (btleier)
no, there was no oil in the garage - I thought the same thing. I let it drain on a level surface with the jack stands set at the same height as well.
You could have bad valve guide seals...but I think that would still mess up your compression...I dunno...you got me.......
saemoonyang
07-15-2009 08:38 PM
bigslimdog
42
03-27-2004 03:02 PM
