What ECU should I use? EG with LS
Old 10-08-2011, 07:15 AM
lazycamper's Avatar
Default What ECU should I use? EG with LS
1995 EG coupe with a LS motor using OBD1 wireing. Tried my D series p28, little bog under 2.3k RPM range. Tried a po6, Runs motor great with no bog but dumps way too much fuel. It's a 1996 b18b1 block with a 1995 b18b1 head. No check engines lights are on except for VTEC on the p28 which is a given. Any Ideas?
Old 10-08-2011, 07:42 AM
virgineg6's Avatar
Default Re: What ECU should I use? EG with LS
Are all of those stock ecu's?
Old 10-08-2011, 07:44 AM
lazycamper's Avatar
yes all of them are virgin ecus to my knowledge.
Old 10-08-2011, 08:05 AM
b16a2ek's Avatar
get the p28 chipped and tuned will run like a champ
Old 10-08-2011, 08:18 AM
Linked's Avatar
p28s are the go to ecu's for OBD1 it seems
Old 10-08-2011, 09:05 AM
HAMOTORSPORTS's Avatar
Use a stock 94-95 P75 ECU and it will run fine if the engine is otherwise stock.
Old 10-09-2011, 05:08 AM
Matt93eg's Avatar
X2.
Old 10-09-2011, 05:48 AM
civiclx1988's Avatar
p-75 with a basemap.
Old 10-09-2011, 08:13 AM
Retired Moderator
EsotericImage's Avatar
X4
Old 10-11-2011, 01:40 AM
aka Paco's Avatar
I've got a P75 ecu out of my 95 integra LS 5 speed.. let me know if your intersted in it, car has low mileage, the ecu was pulled around 128k when a GSR swap was done..
superhatchbackbros
06-16-2011 10:52 AM
nihad
08-03-2010 07:43 PM
wrx'n you
Northeast (Sales)
10-06-2005 10:16 AM
Vtec92Civic
10-03-2004 02:58 PM
TURBOED-TEG
09-16-2002 07:34 AM
Quick Reply: What ECU should I use? EG with LS
