95 Civic EX 2 door coupe - Doesn't Rev past 4000 rpm
Old 08-18-2015, 01:17 AM
Darrell Woods's Avatar
Default 95 Civic EX 2 door coupe - Doesn't Rev past 4000 rpm
My friend Steve posted what I am about to Reiterate..
This Civic came with a D16z6 engine and Automatic Transmission. They popped a timing belt, then replaced the engine with a D15B vtec-e engine. Didn't change Anything. Straight bolt in. Now the car Doesn't Rev past 4000 rpm's. What Is the ECU that Goes with this D15b vtec-e??
Another thing. How do i Identify if this is a JDM engine Or OBDII '96 or newer engine place in my obd1 computer system.??
Old 08-18-2015, 09:05 AM
I'm not Rick!
rick_rabies's Avatar
Default re: 95 Civic EX 2 door coupe - Doesn't Rev past 4000 rpm
on the front of the engine it has a block stamp. that stamp tells if you where it came from. also there is a vin tag on the back of the block. it will tell you even more.
the vtec-e i beleive uses a propriety ecu. an ecu that controls rpm because of the "E" vtec. 3 stage yes? some1 in the market place is selling a 3 stage vtec-e ecu..
Old 08-18-2015, 04:54 PM
tollickj's Avatar
Default Re: 95 Civic EX 2 door coupe - Doesn't Rev past 4000 rpm
Your ECU is in protect mode.
tollickj's Avatar
Do you have a engine check light?
Old 08-18-2015, 05:18 PM
No check engine lights
Old 08-18-2015, 05:21 PM
No check engine Lights I ran codes. No Codes....
Old 08-18-2015, 05:28 PM
The car runs and drives fine No issues what so ever but Will in no way rev past 4000 rpms
Old 08-18-2015, 06:11 PM
Stancetard Hate Monger
eghatch9295's Avatar
what ecu is in the car?
Old 08-18-2015, 10:15 PM
My engine code is d15b.valve coversays vtec-e
Old 08-18-2015, 10:28 PM
Old 08-19-2015, 03:06 PM
I have a p06-a02
Old 08-19-2015, 08:58 PM
My ECU is p06-a02
Old 08-20-2015, 12:34 AM
not even close to the correct ecu. usdm p07 will work, if your jdm d15b is actually a vtec-e variant.
Old 08-20-2015, 01:57 AM
Thank you very much eghatch9295
Old 08-20-2015, 10:06 AM
Old 08-22-2015, 01:37 PM
I found out this engine d15b with a head code p07-1 is actually a d15z1 motor... huh. What a pain in the ***..
Old 08-22-2015, 10:23 PM
ok, you need the p07. make sure you have the 5 wire o2 sensor on it, egr valve, etc. posting a pic of your engine would be helpful.
Old 08-22-2015, 11:25 PM
-Intl Steve Krew
Caoboy's Avatar
<p>This sounds so familiar to W95's car.&nbsp;</p>
Old 08-23-2015, 12:48 AM
I am going to Build a b20 block with a vtec b18c3 p72 head. Tired of this Tiny pain in the ***..
Old 08-23-2015, 01:37 AM
crap. i missed that it is an auto trans. there is no p07 at ecu. you may be able to have your p06 chipped to run the z1, but i doubt it. odds are that they re used the ex trans, the p06 at ecu will not run the trans correctly if that is the case. you'd need to start with a p28 at and go from there.
Mitch Ixcoy
08-19-2018 08:31 PM
Diregraf_Capt
14
12-09-2014 11:42 AM
shadowgeist
01-02-2014 03:24 PM
lovelove
10
10-02-2009 10:55 AM
91ef8
09-01-2007 05:57 AM
Quick Reply: 95 Civic EX 2 door coupe - Doesn't Rev past 4000 rpm
