What does this Connect to?
Old 04-05-2012, 02:02 PM
Killercocopuff's Avatar
Default What does this Connect to?
Hi H-T,
Wanted to see if you guys knew which connector this was? The wiring Harness is off a 1996 Honda Civic DX. Motor is a 1999 Integra LS.
Thanks in advanced!
Old 04-05-2012, 02:44 PM
98EJ7Y8's Avatar
Default Re: What does this Connect to?
evap canister
Old 04-05-2012, 03:48 PM
I'm currently using the stock 96 DX EVAP canister that came with the car and getting a P1457 code. If i get a LS Canister will the connector plug directly with it and should the code go away then?
Old 04-05-2012, 03:51 PM
Former User's Avatar
What are the two wire colors? It looks like one is Red/Yel. What is the other one? Or post a clearer picture of the two wires.
Old 04-05-2012, 06:18 PM
oleskooljoker's Avatar
Air intake temp sensor? thats what it looks like to me...
Old 04-05-2012, 06:22 PM
98EJ7Y8's Avatar
looks like it could be a solid yellow
Old 04-05-2012, 06:27 PM
98EJ7Y8's Avatar
http://www.homemadeturbo.com/showthread.php?t=72286
Old 04-05-2012, 06:32 PM
98EJ7Y8's Avatar
i can check my plugs for u tomorrow on my d16 .. if u dont find out tonight ill check in th morning for you
Old 04-06-2012, 08:11 AM
Wire colors are red and yellow/black.
Old 04-06-2012, 08:27 AM
I don't think so. Can you post a better picture? In the above picture, one wire looks Red/Yel not Red. And is the other wire Yel/Blk or Blk/Yel?
By convention, the first color is the main wire color and the other is the stripe color.
Old 04-06-2012, 10:36 AM
Old 04-06-2012, 10:42 AM
jbpnoman's Avatar
Looks like red/silver and white/silver to me?
Old 04-06-2012, 12:13 PM
98cdmej6's Avatar
the plug is either to IAT or evap,
Old 04-06-2012, 12:21 PM
If it is an EVAP connector are all of them compatible? Like can i use it to plug into a Integra canister etc?
Old 04-06-2012, 12:41 PM
98cdmej6's Avatar
i have a 98 with a LS swap too so. (for me that plug show up three times)
that same type of plug connects to the EVAP selinoid, on the IM, and the EVAP canister, pass. side firewall.
(as well as the old IAT, for the d series)
i dont think i get your q tho, it should just plug right into the civic EVAP canister, or is it not in there?
Old 04-06-2012, 01:07 PM
I have the 96 civic DX EVAP canister on right now and there's no place to plug in this connector. all i see is 2 vacuum hoses. Do i need to get a Integra Evap canister?
Old 04-09-2012, 11:26 AM
98EJ7Y8's Avatar
that would be ur best bet ..
Old 04-09-2012, 12:05 PM
kyden's Avatar
it goes to the purge solenoid on top of your intake manifold.
efcivic317
03-30-2014 04:47 AM
noender
12-05-2010 12:08 PM
chitsard
03-15-2004 01:28 PM
Hondasaurs
05-06-2003 06:42 AM
Quick Reply: What does this Connect to?
