what to do if a screw is stripped?
hey, i was trying to open my foglights up to replace the bulb with a higher wattage bulb. there are 3 small screws to open it up. the screws were so damn tight i used wd-40 and ended up stripping the head w/ a phillips screwdriver. so now i can't open the ****** up and the screws are still pretty tight . what do i do? I was thinking on using a dremel and making a slit in the head so i could use a flathead screwdriver but it would be a little hard. any suggestions?
Unceasing Measure
Re: what to do if a screw is stripped? (mph6563)
That's a baaaaaad place to strip a screw.
I'd definately try a dremel slit and slotted-screwdriver before anything else.
Re: (rodrez)
this happened to me just a week ago with the screws holding on the rotor.....
take a flat head screw driver, place it into the head...
get a hammer, and start hammering it in there so you make your own indentation...
when you are deep enough, just go ahead and unscrew it out....
kinda ghetto but it works, i thought i was fucked when i stripped that screw but i got the tip from a friends dad....
good luck...
good luck...
Unceasing Measure
Re: (toEknEEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg »</TD></TR><TR><TD CLASS="quote">this happened to me just a week ago with the screws holding on the rotor.....
good luck...</TD></TR></TABLE>
Hey genius, it's his foglight assembly. The hammer or impact-screwdriver trick isn't an option. Have you ever seen the Civic foglight assembly? Didn't think so. If you did, you'd know that the screws he's talking about are placed so that hitting them with a hammer would shatter the foglight (which would be contacting the ground).
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">dremel can cut a slit easy, i suggest screw extractor set from sears</TD></TR></TABLE>
extractors work great.
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">chainsaw </TD></TR></TABLE>
good idea buddy
good idea buddy
Re: (jwn7)
buy a cheap screwdriver (and kind that will fit in the hole you made) and sand the tip down so it's rough. Clean the hole in the screw out really well, wait for everything to dry. Fill the hole with JB Weld and stick the screwdriver in. Let sit for a few hours and you should be good to go. It does waste a screwdriver though.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">craftsman EZ out
I got out some stripped valve cover bolts with it...good ****</TD></TR></TABLE>
Yup...I like those much better than I like the drilling idea!!
Sassafrass
04-24-2003 11:40 AM
