What do I need for my b18c1 swap???
I am getting this engine -- http://www.jazzproparts.com/Pr...B18c1 -- what else do I need to get to complete the swap? I'm trying to get everything so I can finish it in one weekend, thanks guys!
Re: (Fejery4491)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fejery4491 »</TD></TR><TR><TD CLASS="quote">It's a 1997 Civic EX......can you get me a link for those axles?</TD></TR></TABLE>
Go to Autozone or any parts place, and get axles for any 94-01 Integra.
obd2......and I found a site saying I don't need any new brackets or anything....that I can just use the stock brackets....is this true?? Idk....I think they're wrong....here the link....http://www.enginereplacement.com/htdocs/chart.htm
Modified by Fejery4491 at 9:52 PM 8/4/2006
Re: (Fejery4491)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fejery4491 »</TD></TR><TR><TD CLASS="quote">obd2......and I found a site saying I don't need any new brackets or anything....that I can just use the stock brackets....is this true?? Idk....I think they're wrong....here the link....http://www.enginereplacement.com/htdocs/chart.htm
Modified by Fejery4491 at 9:22 PM 8/4/2006</TD></TR></TABLE>
you need the stock brackets from the GSR plus a few from the civic Si, if im not mistaken
Re: (Fejery4491)
you'll need...
99-00 civic si rear motor mount
99-00 civic si driver motor bracket
b series AC bracket
b series tranny front tranny + top side bracket
b series axles
modify your engine harness
all I can think of now. I have most of these parts. You can PM me or contact me at ssbptegx1@yahoo.com
b series AC bracket
b series axles
would this kit be everything I need as far as engine mounts are concerned? http://www.racerwheel.com/enj-em96b.html
And is this all I need as far as axles are concerned ?http://www.streetimports.com/p...d=361
And thank you all for being so helpful so far!
Modified by Fejery4491 at 10:58 PM 8/4/2006
you can use ALL of your stock mounts, you will need to reuse your d series upper tranny mount bracket, bolted to the b18 tranny, a 99-00 si rear transmission bracket, reuse your d series a/c compressor if you want a/c and get a cr-v ac bracket. your powersteering line will most likely not mount to the new motors power steering pump.
you will need to run a wire from the knock sensor to the ecu, extend the lower 02 sensor wires a tad bit, possibly extend the vtec wires and thats about it. i wish i had gone obd2. saves alot of wiring and time.
Re: (Fejery4491)
yeah, those axles will work, but go to autozone and buy them because they come with a lifetime warranty.
i would stick to hasport or innovative or az race machine mounts. i bought avids and they suck. ive never even heard of the ones you posted.
youngwon22
10-14-2003 07:47 PM
