What do i need to install CTR front swaybar in a EK?
New User
figure i need the front swaybar and the LCA. will i need the forks? i did a search and people are saying the CTR front swaybar is the same as the SI. is this true?
Re: What do i need to install CTR front swaybar in a EK? (Unjockable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable »</TD></TR><TR><TD CLASS="quote">figure i need the front swaybar and the LCA. will i need the forks? i did a search and people are saying the CTR front swaybar is the same as the SI. is this true?</TD></TR></TABLE>
Yes you will need the forks and yes it is the same.
New User
Re: What do i need to install CTR front swaybar in a EK? (EkDave)
how would the ride be with CTR 26mm front and ITR 22mm rear in a 96 hatch? or should i go with EX 22mm front and ITR 22mm rear?
I have the 00 civic si 26mm front swaybar, LCAs, and forks....I also have the Comptech rear swaybar/tiebar combo (22mm 3-way adjustable). The ride got a little firmer but what a difference...this has got to be one of the best suspension mods you can do. If you want to carve corners and have great handling the si/ctr front swaybar is the way to go. I have a 98 hatch by the way. If you do get the LCAs and forks, don't forget to get ctr or si bolts to attach the forks to the LCA...your stock fork bolts won't work (too short). Just a little advice....this happened to me.
klomast3r
11-05-2005 04:08 PM
SPOONfdEK
21
08-08-2003 03:08 AM
