What causes b16 to make brown smoke at high rpms?
1 Post
My b16 with 132k miles on it makes alot of brown smoke at high rpms. The motor is stock and is well maintained. How can I determine if this smoke is something serious or not?
Re: What causes b16 to make brown smoke at high rpms?
it's going to run a little bit rich at high rpms stock, I know I typically didn't get above 5k more than once every 300 miles so it would be a little black for a few seconds after the crossover.
If it's not more than a "few seconds" of carbon build up you probably should at least start with a compression test and inspect the spark plugs.
Leaky valve seals.. When your in higher rpm's and your in vtec there is more, higher pressured oil running through. and causes them to leak when they normally wouldnt.. . thats what was wrong with my b16a2. check it out.
1 Post
I thought valve seals only leak if the oil is not changed at correct intervals? Also, aren't leaky valve seals a cause of WHITE smoke? My smoke is black. What is the fix for leaky valve seals? Is it an expensive job laborwise?
White smoke is coolant, black smoke is fuel, blue smoke is oil. Valve stem seals will go bad after a while and harden. This will typically first be evident when the car sits for a while and is started. Upon starting it, there will be some blue smoke as it burns the oil that has passed the stem seal and wet the cylinder top.
Valve stem seals are notorious to go out in Honda motors. All Hondas burn oil in Vtec, even brand new or freshly rebuilt motors. It's not a huge issue until you start to burn up a lot of oil even during normal driving. I'd advise you to do a compression and leakdown (most important) test.
1 Post
I pulled my plugs and installed new ones with new wires. The plugs I pulled look to be the factory plugs from Denso. Wires were dated 1999 as well..... I'll get a pic up tomorrow, but the plugs look pretty good in my opinion....
Did you replace them with OEM wires? Can't beat OEM or NGK blues. Anyways, I don't know what would cause a brown smoke. You 100% sure its brown? Never heard of brown smoke. You using oil on the stick? Any signs of coolant loss? If not, I wouldn't worry about it.
FLCivic
02-19-2003 07:10 PM
