weird oil leaking problem...
whats up everyone. i have a 97 ex coupe d16y8. i just turbod it this summer. anyway i got a new oil pump oem honda and ported and shimmed it. ever since i installed it i've been leaking oil from what seems to be the crank. it seems like its leaking from between the pump and the block. could i be missing a seal or soemthing??
and now heres the weird part. i drive 2 hours from college to home. and if i'm driving at 80mph at almost 4k rpms..i'll lose almost a quart in that time. but if i'm goin like 60 at 3k i will lose barely any.
i want to fix it but i'm not even sure what to do.. so what do u all think?
Re: weird oil leaking problem...
idk about your leak situation though. bump for you though
its your front main seal. mine leaks to. i mistaked i for the oil pan gasket leaking and it wasn't it. there is a weep hole that allows oil to drip from behind the crank when it leaks
can it be fixed?
so replace the front main seal? do u have any diagrams of it?
is it just a black circle? and will i need to take off the oil pump or no?
its just a black circle. you wont have to mess with the oil pump. just take off your acc. belts, take off the lower cover, pully, and your T-belt. i dont remember the exact way but its close to this. its basicly behind the crank pully. i only have info or getting the seal out but not the whole procedure. just use a small screw driver to pry out the seal
hatchinprogress
01-07-2006 07:48 AM
