Weak Spark?
Weak Spark?
Alright, so I was driving home one day just cruising down the hwy, came to my exit and stopped at the light. My whole car started to shake. Felt like a really bad mis-fire or a bad mount. So I drive it home, has no power (not like I was trying to accelerate hard). So I get home check for spark.. the spark is orange with a blue outline (weak spark) I immediately think to myself, weak coil, since i have month old plugs, wires, cap/rotor. Test the coil, its fine, test the ICM its fine. But on my friends distribuator, its fine. The weird think is I still get that orangeish/blueish spark with my friends working distribuator???
I checked all the grounds, they are fine. I went for a street tuning session the day before and burned a new chip, I wondered if this had anything to do with it (highly doubted it) so in desperate hope I swapped ecu's with my friends, it still had the "weak spark"
My question is.. is this actually weak spark? I've seen strong spark and weak spark before when diagnosising my friends cars and all the strong sparks were bright blue, mine is a dull orange/blue. Anyways, any input will be very helpful. What else could contribute to weak spark? Ive got a bran new ignition system
btw I checked battery voltage, steady 12V with the car off. Now that I think about it I'll check what it reads when cranking to see if it drops below 9.6V. Maybe my problem isn't with the ignition components..
Re: (ek_chris)
Maybe your month old wire/cap/whatever were defective. Seeing as you have such kind friends see if you can try theirs on your car. Manufacture's defects do happen.
Cheers.
Cheers.
well i checked the resistance in the wires, i know they are good. I've swapped cap/rotors with the other ones i had in my garage. I'm literally stumped.. I need some ideas
