weak clutch pressure
Hello everyone im a newbie here, well heres my first question.
i have just change my Clutch master cylinder and slave cylinder 2 weeks ago. yesterday as i was driving i felt that im loosing pressure on my clutch pedal. ive bled it twice today in sets of 10 pumps. i dont see any leaks from the slave cylinder or the clutch master cylinder. today as i was coming home from shucks i feel almost no pressure at all and when i step on the pedal its already close to the floor.
any suggestion what it might be? ive looked at some related issue and tried the same remedy. my car is a Civic 94 vtec. thanks
Re: weak clutch pressure (japormz)
I've heard of having to bleed these before you even put them on or something like a brake booster, but im not sure. Have you checked for leaks? It could also be a bad one if you didnt get it from honda. Some auto parts stores get batches of bad replacement parts.
Re: weak clutch pressure (z6hatchboy)
Yeah ive been looking for leaks but i see none at all my reservoir is still full. should i have to change the hose that connects the reservoir to the Cluthc cylinder? im thinking it might be my clutch it self, how would i know if my clucth needs to be replace?
i guess no body knows the answer to my problem..... ive just finish cleaning the clutch reservoir and bleed it for the longest time and still the same. every time i step on the clutch it makes this weird sound i wonder what it is?
hey make sure u have ur chilton's manual for your car i had the same problem before after i put a new clutch and i just wanst bleeding it right...i dont rememb3er the exact procedures/steps but if you have that manual handy look it up and make sure your oing it right..hope that helps..
Re: weak clutch pressure (EKway2low)
1. clutch pedal down, open valve.
2. close valve, bring the pedal back up.
3. repeat
easy as 1-2-3 just make sure ur reservoir is always full and doesnt go empty or ur just wasting ur time.
3. repeat
Re: weak clutch pressure (obuhmyuh)
thanks for the replies yes i have done that 123 easy setps and also i do have a chilton book in hand. but the problem is still there grrrr low pressure, im guessing probably my clutcth cylinder could be it but i just bought it 3 weeks ago.
Re: (us92hatch)
Thanks for you guys input. ive finally found the problem the was a niddle like hole in the rubber of my slave cylinder so i replace that . and adjusted the the screw on the back of my clutch pedal thankls for that info. i like this forum i m learning mo than being in school hehehe
T"u"Rtle
04-21-2006 10:17 AM
