VTEC spool solenoid question
code 21 on a jdm d15b, im using the VTEC spool solenoid from my d16a (sohc vtec) motor, is the solenoid model specific or do all d-series motors use the same solenoid?
Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode »</TD></TR><TR><TD CLASS="quote">it either works or it doesnt. There isnt any Half VTEC.
Try cleaning the screen in the solenoid</TD></TR></TABLE>
yeah i know but i have sohc VTEC and its less noticeable.
i did, looks clean, still getting a code. reset ecu too. could it be an ecu issue?
Actually, With an Exhuast on a SOHC VTEC motor it will only drown out the Crossover, Only because the cam is on the Intake side. Not the exhaust side.
Check for crimps in any wires.
Could be the solenoid itself, But that rarely happens. See if you can find someone with an ECU you can borrow.
Re: (ifIexplode)
i have 3 ecus one of them blew up, ill try the other one. i have CAI and headers back exhaust. i tried 2 different solenoids. the wires are a little jack by my ecu tho but i thought i fixed them.
Re: (ifIexplode)
fiddled with it for a bit... i can see a little bit of the gold wires at the base of the VTEC wire, which im 99% sure its the orange wire with a white stripe... where can i but a new ecu harness? but i still think it might be my chipped ecu causing the code...
No VTEC wont work with that code.
I cant see you needing a new harness.
What year is your car?
Easiest way i think to find the solenoid wire at the ECU is to look at the VTEC pinout digrams.
try a virgin ECU.
try a virgin ECU.
Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode »</TD></TR><TR><TD CLASS="quote">No VTEC wont work with that code.
try a virgin ECU. </TD></TR></TABLE>
1995... obd1 my virgin ecu is the one that blew up, all of have left is my chipped ecu and my pr3
Re: (obuhmyuh)
Re: (Mattb16teg)
thanks dooood, i think my prob is my ecu's im using, im using a chipped p06 and a pr3 ecu so they might be a lil funny.
why do u want the mods to delete the thread? maybe itll help someone in the same situation as us. and i know u prob tried to search for code 21 but "21" is too short so people will search by "VTEC SPOOL SOLENOID" and our threads will pop up
good job on the fix btw
Jonathan_ED3
14
07-13-2009 10:31 PM
Tracy
07-30-2004 02:10 PM
