vtec problem , 22 error code
Old Jul 31, 2005 | 10:03 AM
cioli's Avatar
Default vtec problem , 22 error code
so the ecu says error 22
the vtec at high speeds it was kicking in and out and the check engine light turns on at 160 km/h
i looked at the vtec pressure valve ( i don't know exaclty where it is )
i found this picture and i pulled out the '' screw '' and looked for a filter or something like that ( somebody told me ) but i didn't see anthing like this
is this the vtec pressure valve ?
what should i do ?
Old Jul 31, 2005 | 10:08 AM
95excoupe's Avatar
Default Re: vtec problem , 22 error code (cioli)
You see that thing on the top right hand corner of the picture that the wire goes to. Take the two bolts off that and the screen is in there.
Old Jul 31, 2005 | 10:10 AM
Luserkid's Avatar
Default Re: vtec problem , 22 error code (95excoupe)
22 VTEC pressure valve
Check your oil level. Usually this code is thrown because your low on oil pressure (also caused by low oil)
Old Jul 31, 2005 | 10:32 AM
cioli's Avatar
does the vtec have a different oil compartment or you mean the engine oil ????
Old Jul 31, 2005 | 12:24 PM
wutupnut's Avatar
engine oil.
sevenfc
36
Dec 28, 2022 05:01 AM
danteisme
Sep 26, 2004 03:19 PM
BobGnarly
May 23, 2004 05:28 PM
1ntensiveVTECivic
Nov 17, 2003 09:43 AM
