vtec not working. .... what could be wrong. ****
New User
I just notice today that vtec isnt working ..... wire is ok... what else could be wrong/?
it's a b18c1 in a 94 hb yeah i did install the wire myself and it was working for the past 2 years but it dont seem to work anymore. Any my temp. gauage on the cluster doesnt seem to work too.
[Modified by SleeperEG6, 12:30 AM 2/22/2003]
Re: vtec not working. .... what could be wrong. **** (SleeperEG6)
we need more info! what engine? did you do a swap? was it working before? what computer are you running? did you add the vtec wires if you did do a swap or are they in the right place? talk to use!!
1 Post
Re: vtec not working. .... what could be wrong. **** (FifthGearOnline)
Well I'm no hybrid troubleshooting expert - but since the temp. gauge is not functional maybe the car is not able to warm up to Standard Operating Temp...therefore not letting VTEC activate.
I am not sure what you would check to fix that problem...
check the wires all the way back to the ecu, then check to make sure the vtec solenoid is not clogged, the if still nothing make sure the vtec solenoid is still good, then maybe check the oil pressure. let me know
Re: vtec not working. .... what could be wrong. **** (navin)
