Oil Comsumption...PCV Valve?
Old Jun 2, 2003 | 11:42 PM
SixPAK's Avatar
New User
Default Oil Comsumption...PCV Valve?
I did a search and came across this post:
https://honda-tech.com/zerothread?id=325909
Now here's my problem:
The motor D16Y8 with 170,000km's has been burning quite a bit of oil lately.
- I have checked for leaks and all and there are no puddles or anything.
- I did a compression test a few months ago and they were all around 190.
- I am not losing any coolant, and the coolant is clean and so is the oil.
- I swtiched cars with my friend the other day and drove behind my own car, and I could see white smoke when he was on the throttle hard. No blue, no black, just white smoke. And there was a bad smell.
The car runs strong and idles fine. I do my regular maintenance except the pcv valve has NEVER been changed. Would the pcv valve alone cause oil consumption? And what about the white smoke? I thought white smoke was coolant? I don't see any black or blue smoke? So where did the oil go?
Old Jun 3, 2003 | 07:37 AM
JimBlake's Avatar
Default Re: Oil Comsumption...PCV Valve? (SixPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SixPAK &raquo;</TD></TR><TR><TD CLASS="quote">... Would the pcv valve alone cause oil consumption? And what about the white smoke?...</TD></TR></TABLE>
It could. Why don't you replace it and see? They don't cost too much.
Old Jun 3, 2003 | 11:40 AM
Behan's Avatar
Default Re: Oil Comsumption...PCV Valve? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
It could. Why don't you replace it and see? They don't cost too much.</TD></TR></TABLE>
i just replaced mine and it only cost about 2 bucks. that was for the valve only, you most likely will have to change the grommet if its been on there for 170k miles
Old Jun 3, 2003 | 11:48 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil Comsumption...PCV Valve? (93preludevtec)
Your rings might be bad or a valve seal.
Blaze
Old Jun 3, 2003 | 12:28 PM
blah13's Avatar
Default Re: Oil Comsumption...PCV Valve? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Your rings might be bad or a valve seal.
Blaze</TD></TR></TABLE>
He did a comp test and it came out ok so thats unlikely, start with the pcv, its cheap.
Legacy75
Mar 12, 2017 11:24 PM
oldschoollove
53
Jan 25, 2011 04:37 PM
blackmfoggie
Sep 7, 2007 07:34 PM
bosco500
13
Oct 3, 2005 06:12 AM
REEMB18C1
22
May 4, 2005 06:34 AM
