valve adjustments, what do you know?
Re: valve adjustments, what do you know? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">No. Map sensor is caused by bad map sensor, bad wiring, boost, or a leak in the TB or vac. source. </TD></TR></TABLE>
correct
correct
yeah, no boost. when you say leak, would a IACV cause this? is there anyway to clean it.
Re: valve adjustments, what do you know? (philosofy1)
Cleaning it won't affect the leak... if it's leaking it's on loose... if it's dirty it will be clogged and your idle will surge.
Re: valve adjustments, what do you know? (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">Cleaning it won't affect the leak... if it's leaking it's on loose... if it's dirty it will be clogged and your idle will surge.
yeah my idle is surging.
well frankly I"m not sure... I think that you're not supposed to use carb cleaner but I always do... and mine only went a couple weeks ago with 215k miles on the car.
If you have access to a compressor just try to blow out the soot... but I'd just give it a quick shot of carb cleaner and make sure it all dripped out and gave it time to evaporate off before re-installing.
APEXI Si
04-29-2005 11:31 AM
hatchinprogress
11-23-2004 08:21 PM
Kidd_Stylez
11-02-2004 04:14 PM
