Vacume Leak
Vacume Leak
I have a vacume leak on my stock dx motor in my 93 hatch.....the engine is from a different hatch (a 94 dx) and they previous owner replaced all the gaskets. The motor has a vacume leak which is causing the idle to be messed up and what not. It will go from 2000 to 1500 while idling. I have had a few people look at the car, and we cant seem to find the leak...any ideas on how to stop it?
thanks
thanks
Re: Vacume Leak (poopydx)
well you have to find it before you can stop it... leave the car running and start spraying carb cleaner around areas that can leak... the motor will starve itself when it sucks the cleaner in and usually die... then you will know where to look for the leak
Re: Vacume Leak (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">well you have to find it before you can stop it... leave the car running and start spraying carb cleaner around areas that can leak... the motor will starve itself when it sucks the cleaner in and usually die... then you will know where to look for the leak</TD></TR></TABLE>
CRXDaddy78155
09-04-2006 11:42 AM
LilCivic04
09-09-2005 11:28 PM
hatchdrvr
05-08-2003 07:40 AM
hatchdrvr
05-04-2003 07:05 PM
