v-afc troubles :(
v-afc troubles :(
I installed my vafc on my stock 00 Si ecu a couple months ago. I havent touched any of the settings because im waiting to have my car tuned to my mods. today i decided to fool around with the fuel enrichment settings according to throttle position and it didnt work. I had my wide throttle set at 50 and my narrow set at 10. I set my hi cam +3% and left my low can at 0%. I set the vafc to display the fuel correction paramaters and it never changed from +-0% even during the cam switch. All my other sensors are working but this one. Any ideas what the problem could be? All ideas welcomed with infinite gratitude
Re: v-afc troubles :( (saleensolution)
So the sensors check out. i took it out for a spin to double check and the percentage did change. im still confused about the Hi<<lo, Lo<<Hi changeover. I changed the Hi<<Lo to +3% and the Lo<<Hi to -1%, but when i hit vtec it read as -1% when it should have read +3% at WOT, right?
Re: v-afc troubles :( (2lobes1engine)
Dude dont **** with it unless if you know what your doing.
I read the damn manuel twice and i still dont know what the **** is going on with that thing. So im not touching it until i get it tuned.
IgniteTeg
05-02-2002 03:00 AM
