Urgent!! need an answer quick!
Is the rear caliper of an 98 integra same as a 92 civic si. I have a 92 civic w/o abs and need to replace the rear caliper because the piston siezed. I found a good deal on a 98 integra rear calipers W/ABS and mine don't....anyone know if they will work or not??? Thanks!
[Modified by KekeK-18, 3:19 PM 8/1/2002]
Re: Urgent!! need an answer quick! (Spade)
yes it will work, I have a non abs car and I'm using abs rear disk brakes from a gsr. I just chopped off the electrical connectors.
[edit---I think I missread the post...are you trying to use the teg caliper on your existing rear disks?]
Re: Urgent!! need an answer quick! (DragII-Sellout)
Yes I just need to get a new caliper to work with my 92 civic with stock disk and everything....So the answer is NO, I can't use a 98 integra rear caliper on a 92civic si right?
Btw, whats the different between them two? size?
[Modified by KekeK-18, 3:46 PM 8/1/2002]
Re: Urgent!! need an answer quick! (JeffS)
"No, the 94-95 Si (with ABS) calipers are the same as the GSR, but the 92-93 are different."
https://honda-tech.com/zerothread?id=243230
man i just answered an 95 si abs brake question and guys said si's dont come with abs brakes...and now uguys are saying they do...WTF?
mrbigg9032
25
01-14-2013 09:49 AM
mrbigg9032
Suspension & Brakes
21
12-08-2008 08:01 PM
