type r/gsr air box
Old 02-08-2010, 10:17 PM
chiboy002's Avatar
Default type r/gsr air box
are these good? im tryna go oem/jdm style, engine bay having slight adjustments and i wanna know how these are.
What would be a good price for one, and how would it fit in an eg coupe?
im looking at a type r, throw in a k&n drop in, maybe later on go with a cone type filter if i really wanna.
also, are they the same, it looked like it in a picture i got, same size but different tubing
Old 02-08-2010, 11:46 PM
roycivic92's Avatar
Default Re: type r/gsr air box
air boxes are the same, the hoses are diff. i have a integra air box with k&n in my eg hb. looks stock.lol I also have a itr hose.
Old 02-09-2010, 06:00 AM
chiboy002's Avatar
so itll fit? for now immabe putting it on a d16, then when i swap in a b-series ill put in the type r one
Old 02-09-2010, 10:39 PM
roycivic92's Avatar
the d16 tb is too small for the itr/integra pipe
Old 02-10-2010, 10:00 AM
chiboy002's Avatar
damn 4 real? so what, i would have to get an aftermarket pipe?
Old 02-10-2010, 01:15 PM
egsleepercivic's Avatar
you might want to look into an SIRII airbox
http://www.hmotorsonline.com/shop/wh...l.php?prodID=8
it looks the same as stock but the tube is much bigger, I use it with a K&N drop in with my B16a
Old 02-10-2010, 03:45 PM
chiboy002's Avatar
nice, thanks. but how would i set it up with a D? and that box looks huge, will it fit in an eg? cause at first i jus wanna do some cosmetic changes to the car, maybe intake/exhaust manis and all that but nothing too in depth. then in a year or so, once i have the money, i wanna swap b series and build that a little. so i would want it to fit both. how could i?
Old 02-10-2010, 04:37 PM
the box is the same size as the D series the only difference is the the top half of the box and the tube, it even uses the same filter. When you have the tubes next to each other the D tube looks like a tooth pick. I don't know the size of the d series TB but it should be close enough to fit, I even used the d series clamp that goes on the TB
gl
Old 02-10-2010, 04:41 PM
chiboy002's Avatar
gl
would a upgraded tb be worth it, running stock everything pretty much lol, 70mm or b series one, hell if anything ill ghetto rig it for the time being with some gutter piping from home depot!
thanks man
Old 02-10-2010, 04:45 PM
don't think a TB will net you any gains without some other serious engine mods ie turbo cam etc... then you would need a tune, just get a K&N, your not going to see any huge gains with just an intake even if you bought the most expensive one out. You can remove the air baffle/resonator, its a box behind your bumper and connects to the bottom of the air box
Old 02-10-2010, 06:37 PM
mrharmonic's Avatar
i would do it goo when during it rains water whont go in your motor ust will turn off
Old 02-10-2010, 07:23 PM
chiboy002's Avatar
naw, im not looking for power from the d16, just to be able to fit the piping. the dseries would be solely for getting from point a to point b
what?
Old 02-10-2010, 07:42 PM
Originally Posted by chiboy002
what?
thats what I said when I read that post
Old 02-10-2010, 09:36 PM
thumper64's Avatar
Get a CAI and a couple couplers, or a couple intercooler tubing bends and make a pipe that will fit. I did that on a guy's Civic Si and it looks pretty nice.
Old 02-10-2010, 09:57 PM
Koopa Troopa's Avatar
The N1 cars use the stock air box if that says anything....
Old 02-11-2010, 01:30 PM
chiboy002's Avatar
damn that sounds cool, ill try that!
nice
hahahaha i know
EG_BOI6
06-12-2015 05:41 PM
grnaccord
08-25-2011 08:09 PM
Mike N
05-27-2009 04:06 AM
prejdmlude
12-06-2005 08:21 PM
BoroDB8
11-18-2001 06:16 PM
Quick Reply: type r/gsr air box
