Two problems: parking brake and brake drag
Old 01-10-2013, 07:48 PM
bigJOE671's Avatar
Default Two problems: parking brake and brake drag
Car:94' Civic Si
Rear brakes: Stock disc brakes
So I wanted to adjust my brakes according to the manual
I got to step #4 and decided to spin the rear wheels before getting started. Left wheel spun freely while the right wheel had some slight drag. So I made the adjustment nut looser. No change in both wheels so I moved on.
Now I followed Step #4 and got the left wheel to slightly drag but the right wheel had no change whatsoever (still drags before i even adjusted it). So I figured I have a problem and I don't know to begin and I need help on this.
Next I fully engaged the parking brake which was 7 clicks and I pulled till it couldn't go up anymore. Left wheel is locked right wheel spun like before I even adjusted it so there was no change to the right wheel whatsever. That is my other problem
Now I'm thinking this right wheel with slight brake drag is costing me some MPG. Also, the parking brake not engaging on the right wheel is not really gonna help when I do a burnout
Old 01-10-2013, 08:45 PM
Former User's Avatar
Default Re: Two problems: parking brake and brake drag
The two slide pins of the right rear caliper may be seized. Disassemble and grease them so that they slide freely. If they won't, replace the caliper.
dwllama
06-08-2017 02:23 AM
Jriddlez
01-29-2013 06:37 AM
moaterboaink1ng
Suspension & Brakes
10-29-2012 11:42 AM
Honda3133
08-28-2011 05:42 PM
95GGSSRR
09-11-2006 10:39 PM
Quick Reply: Two problems: parking brake and brake drag
