turn signals not working properly
little about what I did before the problem came up.. I wired in ebay fog lights, unplugged the healight harness like the directions said.. hooked everything up. working great. I drove around, next morning I wake up. No turn signals, get home from work take off the housing and noticed the turn signal harness came loose. plugged it back in and had no right turn signal on dash/headlight/tail light.. right turn signal now flashes at twice the rate. checked the turn signal fuse and it's in working condition. replaced flasher relay. and same problem. all help would be appreciated
Re: turn signals not working properly
idk why you would of unplugged it but did you unhook the headlight harness ground that bolts to the engine bay? its a lil off white colored box that bolts on the side of the engine bay near the fender. its the little box on the left..
andoshan
01-21-2016 12:27 AM
pgpunkguy
12-24-2005 04:29 AM
