Turbo on stock b16
Re: Turbo on stock b16
Ahhhhh..... the ultra-rare B16Z6. As you remove it from the engine bay of doom, you have to replace it with a bag of sandblaster media.
poor guy (op)
the correct answer is yes you can turbo it, if its a B series I would keep it around or under 300whp if its a stock motor, and about or under 250whp for a D series due to the smaller rods. the amount of boost doesn't mean ****, every turbo flows a different amount of air per lb of boost and every motors cylinder head flows a diff cfm of air as well, thats why I can run 17lbs on a stock ls motor and not really have any issues with it.
go by whp goals.
go by whp goals.
damnit mrharmonic i wanted to go on with the joke
anyways you ARE upgrading the fuel system when you turbo? (and only referring to keeping the motor itself as stock
if not your not gonna get far with the stock fuel system (and im only meaning like 5 psi max before i'd worry about your injectors)
poor guy (op)
go by whp goals.
go by whp goals.
my stock z6 made 240whp for over a year and a half, dude I sold it to put rc750s in it and turned up the boost and made 307whp for about 4 months then rod went through the block.
