Turbo d16
Old 09-22-2002, 09:36 AM
94si94cx's Avatar
Default Turbo d16
My 94 Si has 146k miles on it. What kind of boost can i safely push through it without an intercooler and with an intercooler? thx
Old 09-22-2002, 09:50 AM
bretx0r's Avatar
Default Re: Turbo d16 (Siturbohybrid)
do numberous tests to see if it can handle. ideally, a stock soch could take 11psi (no joke)
Old 09-22-2002, 11:21 AM
skhonda's Avatar
Default Re: Turbo d16 (bretx0r)
with intercooler i'm going to say 7-8 psi.. *shrugs* 11 psi on stock SOHC are you kidding me?
Old 09-22-2002, 11:25 AM
bretx0r's Avatar
Default Re: Turbo d16 (skhonda)
11psi not daily
but it can handle up to 11psi
Old 09-22-2002, 12:00 PM
beastyboy81's Avatar
im doing 12 daily w/ an intercooler fine. no detonation. just the right fule guys
Old 09-22-2002, 12:59 PM
94si94cx's Avatar
Default Re: Turbo d16 (beastyboy81)
What kind of setup (timing, cams, ignition) are you running to get these kinds of PSI? Also what octane rating is on your fuel?
Old 09-22-2002, 02:00 PM
greddy 5th gen on my 97
12:1 dick
inline pump
apexi vafc
dude dont be gay, call fmax they will tell you that you can run 12 psi on thier turbo and that is a t3/t04e. everything else is stock and my clutch slips in 4th, damm.
Old 09-22-2002, 06:35 PM
94si94cx's Avatar
I'm not being gay (assuming you are talking to me). I just want to know, because I am about to buy the Greddy kit, and I want to know what kind of boost numbers i'm going to be looking at. Does anyone know what the stock boost is on this kit?
Old 09-22-2002, 06:43 PM
ZiggyStardust
Guest
Posts: n/a
With an intercooler and NGK plugs you could safely run 14 psi
Old 09-22-2002, 06:47 PM
94si94cx's Avatar
Default Re: Turbo d16 (ZiggyStardust)
Safely? That just sounds insane. The d16 has such high compression. Just to make sure everyone is on the same page, I have a 94 SI, that is, it is a 1.6L SOHC V-tec. I don't remember the exact compression, but i think it is somewhere close to 9.4:1 or something. That just seems high to be pushing 14lbs of boost.
Old 09-22-2002, 06:54 PM
DSC
DSC's Avatar
Correct fuel management is key.
Old 09-22-2002, 06:59 PM
DUCK COMMANDER's Avatar
Default Re: Turbo d16 (DSC)
all about the fuel....after i get a clutch i am buying some injectors and an SMC or afc and will run 9-11 psi.
Old 09-22-2002, 07:19 PM
CzanSOHC's Avatar
Default Re: Turbo d16 (JSutterEH2)
With an intercooler and NGK plugs you could safely run 14 psi .
you are an idiot.
w/ an intercooler, colder plugs, correct fuel managent, and TUNED, TUNED, and TUNED you can safely run 9-11 daily, but that pushing it.
Old 09-23-2002, 09:20 AM
VSM EXtasy's Avatar
Default Re: Turbo d16 (CzanSOHC)
I"ve been running 13psi with the td04-15G. No detonation, and revving up to 8k rpms daily and racked up over 6k miles driving hard. No blowby and perfect compression. BTW my fuel management is hondata.
Old 09-23-2002, 12:13 PM
b18turbocivic's Avatar
Default Re: Turbo d16 (VSM EXtasy)
If there's a weak link in your engine boost is gonna find it so i recomend you do a leackdown and compression test before you take any further steps.
If you want to turbo your car do it right the first time and you'll save yourself a lot of money so do yourself a favor and get an intercooler you'll be glad you did. If you cant afford one get a used one from a dsm or something. With good tunning i'm sure you could push 9-10psi and be alright....but remeber "tunning" is the key word.
Old 09-23-2002, 12:57 PM
New User
HENRY's Avatar
10-11 psi on a stock d16 with intercooler if well-tuned. I would not try anything above 8psi on stock bottom end. I run 7psi on my intercooled D16Y8 with Greddy kit. Had a friend with a 94 Si with same kit intercooled try running 12 psi (untuned) and he blew the motor after a couple weeks. It better to be safe then trying to push the limits.
Old 09-23-2002, 02:21 PM
Sohc-Vtec's Avatar
I would 9psi daily, and u prob could run 11psi at the track. Without intercooler and stock internals.
Old 09-23-2002, 02:34 PM
Ginuwin3112's Avatar
Default Re: Turbo d16 (Sohc-Vtec)
What 1/4 times are you turbo D16 guys running?? Post level of boost and type of body style. thanks
Old 09-23-2002, 02:55 PM
Mike D's Avatar
Default Re: Turbo d16 (Ginuwin3112)
engine management is so vital to any FI application. I dont have a d16 turbo, so i cant tell you from personal experience, but i would be confident running 10psi daily with the proper tuning.
Old 09-23-2002, 06:44 PM
94si94cx's Avatar
Default Re: Turbo d16 (Mike D)
What kind of power gains are we talking here on the different boost levels? From what it seems, i'm going to probably end up pushing around 9lbs.
Old 09-23-2002, 06:53 PM
AThiker's Avatar
QUOTE]What 1/4 times are you turbo D16 guys running?? Post level of boost and type of body style. thanks[/QUOTE]
I am curious too, and what sort of fuel tuning you did as well, I want to turbo my d16 eventually but need to know how to prepare it.
Old 09-23-2002, 08:19 PM
TREVER's Avatar
[QUOTE]With an intercooler and NGK plugs you could safely run 14 psi .
you are an idiot.
I agree he is one stupid ****, who clearly knows nothing and should not try to help. Peolpe like this do more harm than anything.
7-8 psi max on a stock motor with good tuning
sir boostalot
07-18-2005 10:24 PM
Boostage
03-18-2005 08:15 AM
SOHC50shot
18
03-19-2004 10:49 AM
lazycoEX
03-13-2003 12:04 PM
prjctCIVIC
06-26-2001 03:29 PM
Quick Reply: Turbo d16
