turbo b-series running temp.
hi, just wondering what everyones turbo b is running at temperature wise?
i have an aftermarket guage(autometer)
and in the city my car (turbo ls/v) runs around 165
BUT on the highway(65-75mph)
the car gets up to about 185 at night,
and during the day in texas heat lol,
it can range from 195-205ish.
kinda scares me, so im wondering what is a safe temp.
any help is appreciated, thanx.
Re: turbo b-series running temp.
c'mon guys.
want my car to run cooler!
i have an aluminum half-rad, 12" pusher fan, and 10"puller fan.
mugen thermostat
i even made an air duct out of aluminum.
idk what else there is..
mugen thermostat
I have a boosted b18c block and b16 head and my normal running temp is about 190. I have everything heat wrapped and a vented hood as well.
Having a pusher and puller fan wouldnt help much since youre distorting your air flow.
If anything I would leave the pusher fan on and make a fan shroud like the 240's to force air into the rad to keep your temps down.
Cooling plates help out on 92-95's too so I would look into those if I were you.
you mean the plate that goes on top of the rad where it bolts to the support?
also, what is basically a safe range of temperature?
what temp should i basically cut it off at?
Yes im talking about that plate. They are useless in EK's but they appear as if theyll work on EG's since thers a huge gap between the rad and the rad support.
my setup runs anywhere from 185-195 consistently w/ my stock radiator and fan. i am upgrading this summer, but up to 200 is usually ok.
my turbo LS/V runs 190 pretty much all the time with the stock rad and fan. When it's 105+ outside, it will heat up. My Hondata S300 will throw a warning light at 220 degrees. (even though the stock gauge won't read any higher than normal)
so if you're up to 220, you're pushing it, even if the cluster doesn't say so. Sounds to me like your temps are just fine though.
thanks man, my guage has never read over 205,
but i have always been curious about that.
about the actual limit of where you want your temp not to be.
so i should be ok.
mostly it runs around 180,
but when i run it hard multiple times or get on the highway,
it can get to 200 or 205,
so i was curious.
ok. i only have the aftermarket guage for that reason.
so i should be ok.
so i was curious.
so i should be ok.
so i was curious.
I'm getting the cooling plate just to be a baller. I wasn't aware that they actually functioned. LOL. So I guess I get a bonus.
crazy thing is, I'm building my car, doing all this stuff, and I STILL have the stock radiator and fan. Man oh man.
i ran a stock rad. in the winter lol
but here in texas it gets pretty toasty in the summer.
so i had to upgrade!
EFOwNzALL
06-24-2008 09:09 AM
SWC
03-26-2006 05:41 PM
