Trying to figure out b18b1 problem!
Okay I have posted questions about this topic, but did not get any real answers. Right now I have an obd2 b18b1 in an ej1 ('94 civic ex), with an obd1 p75. I have the engine harness that came with the engine. For some reason the car revs only to 6200 rpm and gives about 17-18 mpg. I put in an automatic p28 and the engine revs to 6500rpms and gives about 20-21 mpg. The car is running and drives good other than those two problems and need help.
Re: Trying to figure out b18b1 problem!
I'll rack my brain on it a bit more, maybe RonJ will pop in. You are going through way to much fuel. I have a B18B1 in my 93 EJ1 and I average 35-36MPG and that's with the shorter geared GSR tranny over its long geared LS brother. 17-18 is WAYY off.
I have a 95 cx with the same setup. b18b1 with the integra wiring harness, obd1 p75 ecu, and car has no where near the power it should and burns gas like crazy too..
Wow, me and a buddy built a CRX with a B1 and it gets like 35-38 mpg and has plenty of power... even with 240K on it.
No it shouldn't. I have a simliar setup, 1994 B18B1 running virgin canadian P75 and I get 35+mpg and has expected power with LS trans.
Are your ecu's 5 spd or auto? Was your engine from a 5spd or auto car?
I've got a virgin OBD1 PR4 5spd ecu if interested.
Are all sensors hooked up correctly and known to be good? Especially the O2 sensor?
Correct spark plugs, wires, etc?
Well my car was an automatic that I converted to manual. It still has the neutral switch (the little white piece that connects to the bottom of the shifter). The computer itself is a manual p75. One of the things I don't understand, I had an ls vtec and a virgin automatic p28 ecu with the intake/exhaust and neutral switch and got 24-25 mpg and that was on the lean side.
On my current setup you can actually tell the car is running rich and also won't go past 6200rpms
Is the ecu known to be good? Can you swap in a known good P75 or PR4? Hows the fuel pressure? Ignition system? Does it idle fine and just cut out at higher rpm? Have you changed the O2 sensor with a known good one?
Obviously something is wrong, but it's gonna be hard to narrow it down.
JBsRomeoAlon
01-12-2014 07:40 PM
Mattcuzko
Engine Management and Tuning
03-12-2011 11:12 PM
97ej6civic
08-14-2009 03:46 PM
