Help with a LS swap
Help with a LS swap
I just swaped a 97 LS into my 93 Civic hatch CX. The car dosent run right below 4,000 rpm the car is not making any power and it also chokes, After 4000 rpm it gets better but its still dosent run right. I am using ob1 ls computer. I am also using gsr engine harness an that ls. I am getting fuel and spark. I also switch the map sensor. Also i changed the ecu. Still runs the same way. What shouls i check next?
Re: Help with a LS swap (JDMdamian95)
If you are using an obd1 ecu to control an obd2 engine, you need to convert certain sensors. You will probably get more help in the hybrid forum
