0BD1 TO 0B0 BLOCK???
Re: 0BD1 TO 0B0 BLOCK??? (vtecb18c)
Yes, I'm curious, too since OBD0 and OBD1 blocks are pretty much identical except for the date code. IIRC, only sensor different is the fan switch is on the thermostat housing instead of the back of the block, you'll need 4 wire O2 sensor and you'll need an OBD1 dizzy;. Everything else will plug in just like an OBD1 engine.
spooncivic1
07-27-2006 04:57 PM
